I use the Service Desk (WIM Jira) for work intake. Once approved the item is then logged into Enterprise Jira for processing. After I link the two Project's Issue Keys, which allows me to initialize the instance in both servers; i.e. WIM-1234 & Ent-9876
When I try to export the CSV file for all of the fields, I am not seeing the Issue Links above. Is there a specific system field and/or labels when there are 2 Jira Servers involved?
It is the "Linked Issues" field when you search in the filter column. It is displayed as "Links" once added.
Ravi
That is correct, but the API is not able to recognize the external server and the field is not pulling any values.
