When documenting i stumbled upon this question and i was confused what is it referring to ? the elements that makes a project unique and different from the other projects or it's referring to the elements that are unique and cannot be repblicated ?
Hello @Kou Ssi ,
The mentioned fields like Name,Key, Description,Avatar, Versions and Components are system fields and they cannot be changed no matter what.
There are also custom fields, that can be changed, since they are created in a custom way.
Hope this helps.
BR,
Nikola
Read the story
