It seems that some changes have been made to the default permissions scheme.
Does anyone now what the permissions are "out of the box installation" of JIRA (Version 6.4.1)?
Atlassian support has provided the default permission scheme by sending screenshots for the correct version
Hi, has anyone has this issue again and has a resolution ?
You can find changes of default permission scheme into admin panel/audit journal
You mean the audit log?
This is a bit complicated as it has over 11000 lines.
Try to search "permission scheme" or "default permission scheme" to filter records.
I have 204 000 lines and use search.
