What's the difference between jira-rest-java-client-core and jira-api?
Deleted user August 13, 2019
Hello there.
Can anyone tell me what is the difference between two dependencies jira-rest-java-client-core and jira-api and which one should I use?
Alexey Matveev
August 13, 2019
jira-rest-java-client is dependency for using Jira Rest Api.
Jira-api to use Jira Java API
Okay, but what does "to use Jira Java API" mean? Can I retrieve data from my jira server via jira-api?
Alexey Matveev
August 13, 2019
You can retrieve data from Jira server via jira-api, if you make your application as an app for Jira (your app must be installed into Jira).
So jira-api dependency is for jira applications?
Alexey Matveev
August 13, 2019
Yes, it is for Jira applications.
That's what I need, thank you!
Muhammad Ramzan_Atlassian Certified Master_
August 13, 2019
jira-rest-java-client is dependency for using Jira Rest Api. You need a  rest client to fetch data from jira using rest services
Jira-api is to use Jira Java API
You  can use java docs to understand the core api classes and can also get the data or perform any action using it.
