×Hi All,
We are using server and our requirement is when we change date picker field the comment field should be required.
Can anyone help with this.
Geethanjali.
Hi @Geethanjali S J ,
in order to make a field required based on other field value or change, you should use a behaviour ( https://scriptrunner.adaptavist.com/latest/jira/behaviours-overview.html ) provided by Script Runner Plugin (https://marketplace.atlassian.com/apps/6820/scriptrunner-for-jira?tab=overview&hosting=server).
Hope this helps,
Fabio
Hi Fabio,
Thanks for the reply l know that we can do this by behaviours can you please send me the script if you have any.
Any example script regarding my requirement.
Geethanjali.
here requested code :
import java.text.SimpleDateFormat
import java.sql.Timestamp
import com.atlassian.jira.issue.CustomFieldManager
Issue issue = getUnderlyingIssue();
def dateField = getFieldByName("HERE_YOUR_DATE_PICKER_FIELD_NAME");
def commentField = getFieldById("comment");
if(issue!=null){
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager();
CustomField dateCustomField = customFieldManager.getCustomFieldObjectByName("HERE_YOUR_DATE_PICKER_FIELD_NAME");
Timestamp dateCustomFieldTimestamp = issue.getCustomFieldValue(dateCustomField)!=null?(Timestamp)issue.getCustomFieldValue(dateCustomField):null;
String dateCustomFieldValue = issue.getCustomFieldValue(dateCustomField)!=null? new SimpleDateFormat("MM/dd/yy").format(new Date(dateCustomFieldTimestamp.getTime())):"";
String dateValue = dateField.value!=null?(dateField.value as Date).dateString:"";
if(!dateValue.equalsIgnoreCase(dateCustomFieldValue)){
commentField.setRequired(true);
} else {
commentField.setRequired(false);
Ciao,
Fabio
Hi @Fabio Racobaldo _Catworkx_ ,
I used the same code but iam getting below error please find the screenshot
Geethanjali.
wht's your jira and script runner version?
we are using jira server version 8.5.1
And script runner version 6.15.0
Geethanjali.
you should add this code in a behaviour and not in console script.
So, create a behaviour, add a mapping to the desired projects/issueTypes and put my code in the intializer (server side script)
Fabio
The code works thanks a lot for your valuable time and information.
Geethanjali.
Hi @Fabio Racobaldo _Catworkx_ , perfect solution I was also looking for. Thank you very much for the code!!
