When I delete a testCase , I met a exception
xinl May 20, 2014
First , I bulk import some testCases and testFolders into JIRA
The testFolder have a link to testCase.
And later , I bulk delete some testFolder in jira.
Now , I meet an issue :
when I want to delete a testCse , I met a exception below :
java.lang.NullPointerException
	at com.atlassian.jira.issue.IssueFactory$1.transform(IssueFactory.java:79)
	at org.apache.commons.collections.CollectionUtils.collect(CollectionUtils.java:632)
	at org.apache.commons.collections.CollectionUtils.collect(CollectionUtils.java:610)
	at org.apache.commons.collections.CollectionUtils.collect(CollectionUtils.java:575)
	at com.atlassian.jira.issue.index.DefaultIndexManager.reIndexIssueObjects(DefaultIndexManager.java:362)
	at com.atlassian.jira.issue.index.DefaultIndexManager.reIndex(DefaultIndexManager.java:382)
	at com.atlassian.jira.issue.index.DefaultIndexManager.reIndex(DefaultIndexManager.java:375)
	at sun.reflect.GeneratedMethodAccessor1258.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at com.atlassian.util.profiling.object.ObjectProfiler.profiledInvoke(ObjectProfiler.java:83)
	at com.atlassian.jira.config.component.SwitchingInvocationHandler.invoke(SwitchingInvocationHandler.java:28)
	at com.sun.proxy.$Proxy131.reIndex(Unknown Source)
	at com.atlassian.jira.issue.link.DefaultIssueLinkManager.reindexLinkedIssues(DefaultIssueLinkManager.java:149)
	at com.atlassian.jira.issue.link.DefaultIssueLinkManager.removeIssueLinkInternal(DefaultIssueLinkManager.java:240)
	at com.atlassian.jira.issue.link.DefaultIssueLinkManager.deleteIssueLinksFromIssue(DefaultIssueLinkManager.java:332)
	at com.atlassian.jira.issue.link.DefaultIssueLinkManager.removeIssueLinksInternal(DefaultIssueLinkManager.java:311)
	at com.atlassian.jira.issue.link.DefaultIssueLinkManager.removeIssueLinksNoChangeItems(DefaultIssueLinkManager.java:288)
	at com.atlassian.jira.issue.managers.DefaultIssueDeleteHelper.removeIssueLinks(DefaultIssueDeleteHelper.java:177)
And in jira log, it shows
/browse/CMCGEN-4711[jira.issue.link.LinkCollectionImpl] Issue[id=50225] links to a non-existing issue!
Can someone know why this happen? And how can I fix this?
Luciano Fagundes
May 20, 2014
Xin,
Apparently you are having some data problems. Please try to run the Jira integrity checker and let us know the results.
https://confluence.atlassian.com/display/JIRA/Using+the+Database+Integrity+Checker
Luciano
xinl May 22, 2014
Thank you very much ,I have fixed the issue by this tool , thank you again
Luciano Fagundes
May 22, 2014
Great I could help! :)
Learn more
