A customer, when cloning an Issue, would like to populate a custom field with the originating/parent Issue's IssueKey but only if the clone is from (or will be used on) a different baseline.
example: If I clone and issue - do nothing. If I clone an issue and the clone will be placed on different baseline, fill a custom field with the original/parent Issue's IssueKey.
Is this possible?
Jim
