In older versions of JIRA it used to take you directly to the ticket you created after clicking the create button. Is there a way for the newer versions to do this instead of just popping up with the link to it?
Hi Neil,
As it turns out, there is no way to achieve that nowadays. There's a suggestion filed at https://jira.atlassian.com/browse/JRA-28758 that you should vote for and also add yourself as watcher to receive updates on it's progress.
