When using reverse proxy, gedget in dashboard failed to display
Ryan July 19, 2018
Hello Team,
We plan to use Nginx reverse proxy to forward 80 port traffic to Jira's port 8080. Configuration has been done. we can access Jira via 80 of most functions. but we found certain gedget in dashboard failed to display. When investigate, we found the gadget is still requestiong to 8080 port directly, and it is not allowed in browser, while main page use 80 port.
Any solution to fix it?
Thank you!
Ryan
Nic Brough -Adaptavist-
July 20, 2018
That sounds like the gadget has a bug, or has a configuration item that allows for a broken url.
Which gadget is it?
Ryan July 20, 2018
In my case,  currently, 2 gadget of 'Time to SLA' add on, which is SLA status Pie chat, TTS - Periodic Met vs Exceeded SlA,
Anther is build in Activity stream.
I see either below error under my dashboard,
We've detected a potential problem with JIRA's Dashboard configuration. Hide Close
Dashboard Diagnostics: Mismatched URL Port
JIRA is reporting that it is running on the port '8080', which does not match the hostname used to run these diagnostics, '80'. This is known to cause JIRA to construct URLs using the incorrect port, which will result in errors in the dashboard, among other issues.
The most common cause of this is the use of a reverse-proxy HTTP server (often Apache or IIS) in front of the application server running JIRA. While this configuration is supported, some additional setup might be necessary in order to ensure that JIRA detects the correct port.
The following articles describe the issue and the steps you should take to ensure that your web server and app server are configured correctly:
If you believe this diagnosis is in error, or you have any other questions, please contact Atlassian Support.
Detailed Error
Click here to learn more
July 20, 2018
Ahh, so you've not configured the proxy correctly.  I am sorry, the question suggested it was just one gadget having a problem.
First, can you check the basics:
  • Your base url is set to the place the users will be using (i.e. the proxy front end, not Jira's 8080 based url)
  • The context is correct (if you are using one at all)
  • Jira's server.xml has the right proxyport, proxyname and scheme settings in the connector
  • The proxy has the matching context and proxypass settings
Ryan July 25, 2018
Hello Nic Brough,
Thank you for your reply,
In fact, I was following this guide https://confluence.atlassian.com/jirakb/integrating-jira-with-nginx-426115340.html to config the reverse proxy using nginx.
  • The base url is exactly the front URL of nginx http://sd.softtekchina.com
  • The context is  <Context path="" docBase="${catalina.home}/atlassian-jira" reloadable="false" useHttpOnly="true">
  • Jira server.xml reverse proxy section is set as:
<Connector port="8080" maxThreads="150" minSpareThreads="25" connectionTimeout="20000" enableLookups="false"
maxHttpHeaderSize="8192" protocol="HTTP/1.1" useBodyEncodingForURI="true" redirectPort="8443"
acceptCount="100" disableUploadTimeout="true" bindOnInit="false" scheme="http"
proxyName="sd.softtekchina.com" proxyPort="80"/>
  • The proxy is matched with server.xml
server {
listen 80;
server_name sd.softtekchina.com;
location / {
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Server $host;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_pass http://sd.softtekchina.com:8080/;
client_max_body_size 10M;
The rest of functions work well, only some gadget.
Thank you
Ryan
July 25, 2018
The only unusual thing I would worry about is that the proxypass should be pointing to where the Jira is actually running, not the proxy.  If they really are running on the same server, then try changing it to the ip address or localhost
Ryan July 25, 2018
Hello Nic,
Thank you for reply!
But It's still not work.
The thing is, when browser requesting gadget, the ones that not work, it's requesting http://ip:8080/plugins/serverlet/xxxx, which I'm afraid after apply reverse proxy, the address didn't get updated. individual request to http://ip:8080 should word. but it doesn't while be a part of body under the main page which is http://url on 80 port.
How can I get gadget address updated.
Thank you!
Ryan
July 25, 2018
The gadgets take their url from the base url, there's nothing in the gadgets to change.
Ryan July 25, 2018
Hello Nic,
Then, something is not work as expected. base url is correct
gadget request url as below
If I put 8080 into the url. them all works well. but it's not desired style, due to some end user can not access 8080 inside of company, due to their network limitation.
Thank you!
Ryan
July 31, 2018 edited
That suggests your proxy is not directing the data correctly then.  The body of the request looks like it is being remapped somewhere, to the old url with 8080 in it
Ryan August 1, 2018
The proxy works as expected, any request goes to 80, direct to 8080. but the gadget request didn't go to 80. why it go to 8080 port. this is my question.
August 1, 2018
The problem is that the pie chart will be making requests on the base url.  I've got the code (because I've hacked it for people a couple of times), and it simply does not use anything else when it goes out to the network.  That means there is something on your network changing that request.
Ryan August 1, 2018
The base url used to be http://x.x.x.x:8080/jira. but right now, it's http://domainName/ now.  I guessit might be cached old url in somewhere.
I'm sure our network doesn't have any special setting against those gadget. neither jira instant itself.
