When using the roadmap plugin, how can I view a hierarchy using implements links
Mitch Kulberg
December 14, 2020
My organization created a hierarchy of work based on customer deliverables, which is fine. But I need to track it from a different view of overall functionality of the whole. So I want to create a parallel hierarchy of themes and initiatives using the "implements" and "is implemented by" links, but those type of links don't show up in the plan view.
Is there a way that I can use a plan roadmap view where the hierarchy is based on these other links as opposed to just parent and child?
I know it's a long shot, but who knows.
Thanks.
Anna-BigPicture
Hello @Mitch Kulberg
In BigPicture/BigGantt, you can automatically create a no-limited number of WBS levels. Task Structure can be created based on both build-in task attributes (e.g., Epic link, Component, Version, Sprint) as well as any links.
Please le me know if you need more information.
Best,
Anna
SoftwarePlant
Kit Friend
December 29, 2020
Hey Mitch,
not really IMHO - the Atlassian Plans/Roadmaps plugins are designed to be used with a normal work hierarchy: how to configure hierarchy levels or how to expose these levels in Jira.
You could trial some other plugins like BigGantt or Structure which let you create plan-like views with automation based on other fields and see if that works for you perhaps?
Help us plant more trees
