×I want to love JEditor, I really do, but if the ability to easily add images is limited to IE then its not a viable option. Most of our users do not use IE, intentionally, and for good reason.
You can paste images into JEditor in any supported browser.
However only IE11 allows to copy text with images from MS Office apps. Other browsers just do not support this feature. This has nothing to do with JEditor. Compatibility between MS IE and MS Office is based on MS part Can't say when Google and/or Mozilla add this support.
Thanks - there are much bigger problems with JEditor that we can't get past. Email notifications are littered with HTML tags instead of properly formatted text.
