Where/How can we get to know the ID value of Components etc..
Nazia Tarannum
March 27, 2012
6 votes
Geoffrey Laparra
The easiest way I found is to go into an issue of the project you want to get the component ID.
Change/add the component needed and read the changes in the history tab 'All'
You will get something like this :
LAPARRA Geoffrey made changes - 5 minutes ago
Component/s                              My component [ 11509 ]
Sergey Pimenov
September 9, 2017
Awesome! Many many thanks! )
Thomas Bithell
This works for Jira 7x
Thomas Bithell
Simple way is to go to Components link in the Jira project. Then view the source code for the page and use CTRL-F to find the component in question. The ID can be found there.
\"id\":27223,\"name\":\"Vandals\",\"issuesCount\":9,\"issuesUrl\":\"/jira/issues/?jql=project+%3D+BWDEMO+AND+component+%3D+Vandals\",\
Thanks again Atlassian for making something that should be easy, harder yet. It used to be you could over the mouse over the component name and see the ID at the bottom of the browser. They screwed that up.
Deleted user June 13, 2018
hi,
i ran across this post https://community.atlassian.com/t5/Jira-Core-questions/How-can-I-find-a-Component-ID-of-a-specific-Project/qaq-p/111851
It shows a lot of ID's including the component ID's.
Deleted user March 12, 2019
Super helpful. Thanks!
tousifs
March 27, 2012
<dl><dd>Hi,</dd><dd></dd><dd> I am still not sure your developing plugin or you want to get it Directly.</dd><dd>but if your developing via plugin then make certern changes to code.</dd><dd></dd><dd>IF your implementing logic for all Unique components then </dd><dd>
final Set<JIRAConstant> components = issue.getComponents();
       if (components != null && components.size() > 0) {
</dd><dd>
           int i = 0;
             for (JIRAConstant component : components) {
</dd><dd>
component.getId(), component.getName();
</dd><dd>
//this way you can get all the components with id.
</dd><dt></dt><dt>if your implementing for the single component</dt><dt></dt></dl>
ProjectManager projectManager = ComponentManager.getInstance().getProjectManager()
you could get the component object based on component object get the Component id.
<dl><dt></dt><dt></dt></dl>
Nazia Tarannum
March 27, 2012
thanks everyone for your answers
Kim Wallace
In Jira 8.13, you have to look in the page code when hovering over the Actions - if you hover over the name you just get the literal path.
Patrick Schneider May 9, 2016
Any idea how to get the ID in JIRA 7?
JamieA
March 27, 2012
It's been made a bit harder recently, probably the easiest way is to go to:
http://jira/browse/PKEY#selectedTab=com.atlassian.jira.plugin.system.project%3Acomponents-panel
ie the components tab on Browse projects, then mouse over the components. The ID is the last part of the URL.
Or, you could look up in the database, or write a groovy script or something.
Nazia Tarannum
March 27, 2012
Sorry for not being precise.
I know where its available in older jira versions, but in JIRA5.0 am unable to find the ID for Components
Mizan
March 27, 2012
Its same for Jira 5.0 , Exit Administration>>Project>>Component Panel>>hover the mouse on the component name in the end of the url you will get the Component id.
Learn more
