i am using JIRA 6.4.10 with the Plugin jira-cvs-plugin.
In the old days of JIRA one had a service 'VCS Update Service'.
In services there isn't this entry anymore.
Where can i set when the plugin should start to retrieve the logs?
michael
This is fixed as 1h on the plugin.
If you really need to change this you may get the source (https://bitbucket.org/atlassian/jira-cvs-plugin) and change com.atlassian.jira.vcs.RepositoryManager.VCS_SERVICE_DELAY to another time in milliseconds.
