Where does jira-config.properties go in JIRA Data Center?
Terry Bearce August 20, 2018
I have edited the jira-config.properties file to add additional transition steps to my issue pages.  I am currently moving from JIRA Server to JIRA Data Center and would like to keep this configuration.  In DC there are two home directories. One is the regular/default home directory and the other is a shared datacenter home directory.  Which of these home directories would be the correct one?
3 votes
Michael Perez
November 27, 2019
The jira-config.properties file must be added to Jira's local home directory, not the shared home directory. The difference between Jira Server and Jira Data Center is that you must add the file to each node in the instance. For more information, see Edit the jira-config.properties file in Jira server.
Alexey Matveev
August 20, 2018
You should put it into the shared home directory.
Terry Bearce August 24, 2018
Thanks for the update, I thought that would be the answer but wanted to make sure.
Alexey Matveev
August 24, 2018
You are welcome!
Eddy Fras
Then, if we want to add/update a property in jira-config.properties in DC mode, do we have to restart each node one by one ?
Eddy
mimacomFlowable Sysadmin Team August 22, 2019
I think this answer is wrong. I put my jira-config.properties to the shared home directory and restarted the nodes, but they don't respect the settings I've configured in the file.
Does that mean we need to deploy the file for all the nodes particularly?
Like • Daniel Törnqvist likes this
Eddy Fras
I agree with you, the jira-config.properties settings are ignored if they are in the shared directory.
See https://community.atlassian.com/t5/Jira-questions/How-to-get-jira-config-properties-effective-on-nodes-in-Data/qaq-p/976681
Is it possible to cancel the "answer accepted" status on this question ?
Like • 2 people like this
