How do I get to Releases or Versions screen?
First you need to add versions. You must be a Project Administrator to add a version. You can find more info on how to create a version here:
https://confluence.atlassian.com/adminjiraserver/managing-versions-938847201.html
Then you can open Projects -> Your project and there will be the Releases menu with versions.
@Alexey Matveev is there any way to customize fields avaliable on screen that appears after pressing the "release" button ?
It is not possible out of the box.
Hey @omaracrystal @Roey Shamir @Alexey Matveev @Evgeniy Buturlia is it possible to add anew field on "release" creation screen?
Hi, you are more than welcome to try my plugin - Version Manager for JIRA cloud.
Not only does it let you delegate the manage versions permission to whoever you decide, but it also lets you assign components to versions.
