I'm working on an integration from ServiceNow to Jira Server, and after much wailing and gnashing of teeth, I decided that OAuth 1.0a was the only option because cookie auth and API Token auth are both disabled on Jira Server. ServiceNow doesn't have the necessary API's to perform the OAuth dance (https://developer.atlassian.com/server/jira/platform/oauth/), so I decided I would have to write a middleware API to perform all the heavy lifting on behalf of ServiceNow. I'd like to use Python because it's what my team and I are most familiar with, but the example Python code for Atlassian OAuth 1.0a is not loading for me: https://bitbucket.org/atlassianlabs/atlassian-oauth-examples/src/master/python/app.py. Does anyone have examples of a Jira OAuth client written in Python?
I checked the Dev Tools in Chrome and the error messages there imply the problem is with the ZScaler gateway (gateway.zscloud.net) which is filtering traffic on my network. Apparently, ZScaler does not like the Python code on the page I'm trying to load. I've opened a ticket with my corporate IT admins.
Hey @David Dietrich ,
I was able to load it here, give it another try, maybe you will can try in another browser?
I've tried Edge, Chrome, and Firefox. All of them return the same error. I will try contacting my IT department to see if their security systems are causing trouble.
That's strange, maybe you can try using another machine? The repository is public , i have downloaded the repository and uploaded as .zip on this link https://gofile.io/d/Omfdwu so at least you can have access to the content
Register now
