Where to find the 'script registry' for ScriptRunner?
Greg Elofson
I'm trying to locate the 'script registry' for ScriptRunner, because I'm trying to identify what scripts have already been used for a jira instance.
Navigating from Admin -> Manage Add-ons -> shows the Behaviors and additional ScriptRunner links. However, there is nothing for a "script registry" -- which apparently exists according to this link:
https://community.atlassian.com/t5/Jira-questions/How-can-I-find-where-ScriptRunner-is-in-use/qaq-p/671426
Attached is a screenshot of the left-side admin panelScreen Shot 2018-11-23 at 1.03.37 AM.png
3 votes
Tarun Sapra
Hello @Greg Elofson
Please go inside "Built-in Scripts" and then you will see "Script Registry" and then you can just execute it and see the usage of the plugins across your Jira instance.
Greg Elofson
Found it! Many thanks! (to my surprise, it was empty...Preview showed no results). More to go.
Jacques B
@Tarun Sapra I assume your instructions were for Jira Server?
Do you know how to find Script Registry for Jira Cloud?
I tried Settings > Apps, then under ScriptRunner there is a Built-In Scripts option, but I only see the following options:
  • Bulk clone issues
  • Bulk fix resolutions
  • Copy custom field values to another field
Robert Horan December 7, 2023
I cannot find it there either.
Register today
