×I have tried XML/RPC , REST , and Python CLI, only Python CLI seems to worrk, and only on 4.1.2 version of Jira.
From the example, i tried to access: and i tried several jira instances
https://jira.atlassian.com/rpc/xmlrpc
but got error:
<name>faultString</name>
<value>
java.lang.NoSuchMethodException: com.atlassian.jira.rpc.xmlrpc.JiraXmlRpcService.getVersions()
</value>
</member>
<member>
<name>faultCode</name>Can someone tell me which API works with jira 4.4., or jira 4.1.2 onwards.
They all work and are used by many people, but do require proper setup and use :). JIRA Command Line Interface is also available. Both of the CLIs rely on JIRA interfaces like XML/RPC, SOAP, REST, and in a few cases JIRA UI access.
Yes, thanks Bob, The Documentation is a bit terse though
getIssue java.util.Hashtable getIssue(java.lang.String token, java.lang.String issueKey) throws java.lang.Exception Gets an issue from a given issue key. The Hashtable returned have nested Hashtables for keys, components, affectsVersions, fixVersions and customFieldValues. Parameters: token - issueKey - the key of an issue (e.g. JRA-111)
token actually means the return object from jira1.login("","")
i could not get SOAP to work, since SOAPy is no longer updated.
