While Using JIRA Cli to modify data in jira it gives SSL error
Abyakta Lenka September 30, 2014
It throws error
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
i am using 3.9 version and i am a new user of this product.
Tiago Comasseto
September 30, 2014
Hi Abyaka,
This error means that JIRA HTTPS certificate couldn't be found in your local JAVA cacerts. You can either import the certificate as in this doc, or edit JIRA CLI files as following:
Into the jira.sh or jira.bat you'll have a connection string like this:
java -jar `dirname $0`/lib/jira-cli-3.9.0.jar --server https://jira.example.com --user automation --password automation
You could include the parameter -Djavax.net.ssl.trustStore=/path_to_cert
I hope it helps.
Cheers
