  • Community
  • Products
  • Jira
  • Questions
  • While adding Java script to my custom field's Description it is not working. I want to align the custom field. What should i do??
Amrusha Nekkanti July 26, 2016
Bharadwaj Jannu
July 26, 2016
Align in the sense do you want to re order your customfield? How do you add? Do you add the script in the customfield in the field configuration or directly in the customfield description?
Yes, i want to re order the custom field and yes, iam adding the JSS directly to the description field.
Thanks  for your response.
Bharadwaj Jannu
July 26, 2016
why don't you add the javascript in the customfield of your project field configuration it worked for me when I add in the field configuration. Also you can change the order of the customfield directly in the screen but it will be global to all projects using this screen.
Ok, sure then i'll try it thanks......
Actually when iam adding the script to the description field its being automatically updated in the field configuration. But for confirmation i have added once more and its not working, is anything going wrong??
Bharadwaj Jannu
July 26, 2016
If possible, can you share the script?
This is the script for removing the "none" option in the field
<script>
AJS.$('#customfield_10200 option[value="-1"]').remove();
</script>
Bharadwaj Jannu
July 26, 2016
Can you try the below code block.
&lt;script&gt;
AJS.$("#customfield_10200 option[value='None']").remove();
&lt;/script&gt;
No, this is too not working.
Bharadwaj Jannu
July 26, 2016
Can you add your script in the comment field in the field configuration.
Register today
