While creating an issue iam getting an error as attached below what could be the issue ?
ravikiranreddy May 31, 2016
Teja
May 31, 2016
Please check Field Configuration. If field configuration is OK check in the workflow validator.
Nic Brough -Adaptavist-
May 31, 2016
To explain why: You have made a field called SLA Comments mandatory for the issues, but not put it on the creation screen.
Teju's answer is most of the rest of what I'd have typed - although a third fix would be to add the field to the screen.
