  • Community
  • Q&A
  • Jira
  • Questions
  • While trying to Google Docs in JIRA, its gives a java.lang.NullPointerException: No authentication header info - solved
Anand Kumar Singh October 10, 2012
While I am trying to Google Docs in JIRA Integration.when i click on search its gives error java.lang.NullPointerException: No authentication header information.I have also attach the screen shot of error.
Patrick Li
October 29, 2012
Generally speaking, I would recommend checking
#1, make sure your Google OAuth key and secret are correctly configured in JIRA. Be careful with trailing white spaces if you are cut & pasting them in.
Regards
Patrick
Ellen Feaheny [AppFusions]
October 31, 2012
Arnand -
Contact us at info@appfusions.com if you are not running yet.
This works, I assure - and we have many customers running with it. But the initial Google configs are "picky" -
Ellen
ellen@appfusions.com
Patrick Li
October 29, 2012
Hi Anand,
What version of the plugin are you using?
Regards
Patrick
