Who is using what plugins?
Kannan S
Is there a way in JIRA api to find out the list of users using a specific gadget/plugin?
How is the user and plugin mapped? ie., how does the jira identifies a user's plugins.
Say there are two users.
User A is using the "Assigned to Me" gadget.
User B is NOT using the "Assigned to Me" gadget.
How do i programmatically find out the list of users who are using the "Assigned to Me" Gadget or any other "user-installed" add ons?
A few plugins are used by a specific group or common to all.
How do we know whether a plugin is used by a user or groups?
Ubisoft
December 16, 2013
I would suggest using the DB since you cannot with the API.
example :
SELECT * FROM portalpage p, portletconfiguration pc where pc.portalpage = p.ID and gadget_xml like '%GADGET%'
