Why Jira use an old version of my custom plugin?
Manuel Chanivet Roca February 16, 2022
I have a custom plugin running in a Jira 7.9.2 and I have made a simple modificaction. But when I install this change and try to test, I see that is the previous version of the plugin.
I try without results:
  • compile the plugin with a higher version and install it.
  • uninstall the addon and install a higher version.
  • clean the jira .osgi-plugins, .bundled-plugins, cache and temp and reindexing after restarting jira
  • check that there are no stale entries in the pluginstate table
I replicate my jira environment in other jira and the change have installed well.
I do not know what else to do. Any ideas?
Julio Sánchez Cuenca
April 28, 2022
same error
Learn more
