Why Rest API call is not working?
Scheibli Márk August 17, 2017
Hello!
At the moment i'm working in js with Rest API. I want to get the issues for a project on this way:
$.get(AJS.contextPath() + "/rest/api/2/search?jql=project=" + is_data, function( data ) {});
It is working like this:
If the is_data are the names of the projects then if i try to get a two words named project's issues i get an error message, but if i try with one words named projects then it is working totally fine. If i try to put the project keys in the is_data, then it is working fine with the two words named projects and some of the one word named projects but if i have a project named like this: OneTry, then the key is ON and it can not get the issues because of failed Rest API call.
I totally don't know what is the problem. Should i somehow transfer the two words named projects?
Aleksandr Zuevich
August 17, 2017
Hi, try to add single quotes to each project name.
Yes, that is the best option.
