After issue saved i am trying to update status using TransitionId but it always returned failed.
Hello Ramesh,
To change the status you will need to transition the issue
Check out:
Use the format:
curl -D- -u user:pass -X POST --data {your-json-data} -H "Content-Type: application/json" http://<BASE_URL OR IP:PORT>/jira/rest/api/2/issue/<ISSUE-KEY>/transitions?expand=transitions.fields
With the json data something like this:
{ "update": { "comment": [ { "add": { "body": "Put a comment here" } } ] }, "transition": { "id": "#" } }
Earl
