Has anyone else seen this, I swicth to another dashboard from favourites list down the left-side of the screen & am immediately presented with the 'you do not have permission to see this, you may need to login', if I login the dashboard displays correctly.
It also happens occassionally when clicking through to the project summary page by clicking on the project name.
Cheers
Norman
No, all the gadgets/filters on the dashboard are owned by the project. Also, strangely, it hasn't happened for the lst 20mins - off to trawl through the logs I guess :-(
Do you have any admin related gadgets on one of your dashboard? sudo access might be playing with you here
Doesn't seem to, for ex. I'm on this page
http://jira.xxx.com/secure/Dashboard.jspa?selectPageId=10141
and switch to another dashboard and the url for that is
http://jira.xxx.com/secure/Dashboard.jspa?selectPageId=10147
and now it's working again intermittantly :-( I wonder if something else is molesting the cookie?
Does the url change when you do that? If the base url differs then your cookie will not be valid possibly.
Read the story
