Why are stories and tasks strike through before done?
Dipika dhingra June 30, 2015
My stories/tasks are strike through as soon as I move them in progress, that is not how I want it. Please help me to change it.
Udo Brand
June 30, 2015
Issues are striked through as soon as they have a resolution. It seems that while transitioning to In Progress a resolution is set via post function. So take a look at the post functions in that transition.Remove that postfunction and possibly add it to some other transition( e.g. to resolved/closed status) in order to set a resolution there.
Nic Brough -Adaptavist-
June 30, 2015
I always forget you can set a resolution with a post-function too.
Udo Brand
June 30, 2015
And I didn't think of that in the transition screen could be the resolution field...
June 30, 2015
I suspect you have put the "resolution" field on a screen it should not be on - when the users edit the issue or go through a transition that uses a screen with resolution on it, they are (inadvertently) setting the resolution.
Go over all your screens and remove resolution from all of them, except screens that are used on transitions where you want to set it (i.e open > resolved or in-progress -> closed)
Once you've fixed that problem and stopped damaging your issues, we can move on to fixing the broken ones.
