I've writen a Bultin Script Listener "Send a custom email". In this listener I've included the condition:
cfValues['ENT_NOTIF_ESCALADO'] != null
The customfield ENT_NOTIF_ESCALADO is the customfield used in the field: "To issue field". The content of this customfield is the list of email addresses to send in the email (i.e: person1@xxx.es, person2@xxx.es, person3@xxx.com). The idea is not to send the email in case of the list was empty.
I've tested the listener with an issue on which the customfield ENT_NOTIF_ESCALADO has value and the result is ok, in the preview it is shown to me that the result of the condition is true.
However, when I test the same listener using an issue on which the customfield ENT_NOTIF_ESCALADO has no value, the result is:
java.lang.NullPointerException: Cannot invoke method split() on null object at org.codehaus.groovy.runtime.NullObject.invokeMethod(NullObject.java:77) at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.call(PogoMetaClassSite.java:45) at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42) at org.codehaus.groovy.runtime.callsite.NullCallSite.call(NullCallSite.java:32) at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42) at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.call(PogoMetaClassSite.java:54) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116) at com.onresolve.jira.groovy.canned.workflow.postfunctions.SendCustomEmail.getAddressesFromFields(SendCustomEmail.groovy:507) at com.onresolve.jira.groovy.canned.workflow.postfunctions.SendCustomEmail$getAddressesFromFields.callCurrent(Unknown Source) at com.onresolve.jira.groovy.canned.workflow.postfunctions.SendCustomEmail.getAllToAddresses(SendCustomEmail.groovy:438) at com.onresolve.jira.groovy.canned.workflow.postfunctions.SendCustomEmail$getAllToAddresses.callCurrent(Unknown Source) at com.onresolve.jira.groovy.canned.workflow.postfunctions.SendCustomEmail.getDescription(SendCustomEmail.groovy:575) at com.onresolve.jira.groovy.canned.CannedScript$getDescription.call(Unknown Source) at com.onresolve.jira.groovy.CannedScriptListener.getCannedScriptHumanDesc(CannedScriptListener.groovy:121) at com.onresolve.jira.groovy.CannedScriptListener$getCannedScriptHumanDesc.callCurrent(Unknown Source) at com.onresolve.jira.groovy.CannedScriptRunner.doExecute(CannedScriptRunner.groovy:210) at com.onresolve.jira.groovy.CannedScriptListener.super$6$doExecute(CannedScriptListener.groovy) at sun.reflect.GeneratedMethodAccessor1188.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:90) at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:233) at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1054) at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.invokeMethodOnSuperN(ScriptBytecodeAdapter.java:128) at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.invokeMethodOnSuper0(ScriptBytecodeAdapter.java:148) at com.onresolve.jira.groovy.CannedScriptListener.doExecute(CannedScriptListener.groovy:33) at webwork.action.ActionSupport.execute(ActionSupport.java:165) at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:87) at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:39) at webwork.interceptor.NestedInterceptorChain.proceed(NestedInterceptorChain.java:31) at webwork.interceptor.ChainedInterceptor.intercept(ChainedInterceptor.java:16) at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:35) at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:225)
NOTE: I've tried to use also the conditions:
Any idea?
Thanks in advance
Begoña
Non-standard custom fields are not supported, as there's no standard way of retrieving the value from them and parsing it.
It is a Database Information customfield as you can see in the screenshot
It is called ENT_NOTIF_ESCALADO (all upper case)
Versions:
JIRA 6.1.7
Script runner 2.1.16
Here you have the screenshots with the configuration and the result with:
ENT-17297 on which the ENT_NOTIF_ESCALADO has no value
ENT-17298 on which the ENT_NOTIF_ESCALADO has value
thanks. What type of field is ENT_NOTIF_ESCALADO ? Is it called like, all upper case?
Perhaps it's an empty list.
Just use:
and let "groovy truth" do the work.
can you attach a screenshot of the config and include the versions.
Read the story
