Why clone a jira does not clone the Zendesk link?
Jennifer Zou
Hi Everyone,
I am wondering that why when I cloned a JIRA, the cloned JIRA does not inlcudes the linked Zendesk ticket info? How could I clone it with the Zendesk ticket info?
Jennifer.
Brant Schroeder
How is the Zendesk ticket info stored in the issue?  Is it a comment?  Is it a custom field? Etc?
Jennifer Zou
Hi Brant,
It is an add-on App which listed on the right panel bar.
Thanks.
Brant Schroeder
Does the content in the add-on use database fields created by the add-on or does it pull from custom fields that the add-on creates?
My guess is that the add-on uses it's own database fields in which case the clone function will not copy them.  If the add-on uses custom fields then it will copy the data.
A clone issue retains the following information:
  • Summary
  • Description
  • Assignee
  • Environment
  • Priority
  • Issue Type
  • Security
  • Reporter
    (If you do not have the Modify Reporter permission, the clone issue will be created with you as the Reporter.)
  • Components
  • Affects Versions
  • Fix For Versions
  • Issue Links (optional)
  • Attachments (optional)
  • Project
  • Custom Fields
Jennifer Zou
Thanks! Got it.
