I am use Jira software data center version 8.20.
The custom field "Requirement Status" is not show on the issue screen. Please help fix the problem. Thanks!
custom field
Can not find it on the screen
where is "Requirement Status"
Thank you for your quickly replying!
I added it to "Requirement Projects" and tried create one more requirement ticket. But still cannot view "Requirement Status" field. Any other clue. Thanks!
Hi @Owen
Have you added the project to the Requirement project in the Xray configuration ?
https://docs.getxray.app/display/XRAY31/Requirement+Projects
And added the type to the requirement configuration ?
https://docs.getxray.app/display/XRAY31/Issue+Type+Mapping
Regards
Did you properly configure the Issue Type Mapping section ?
It was fixed after I add "Requirement" to "Requirement Issue Types".
Thank you for your help!
