I am use Jira software data center version 8.20.
The custom field "Requirement Status" is not show on the issue screen. Please help fix the problem. Thanks!
custom field
Can not find it on the screen
where is "Requirement Status"
Still cannot see “Requirement Status” field in my screen.
Can anyone help on this case? Thanks!
Does this field contain data? If it does, it should appear on your View screen.
If not, click Edit and try to set the value first.
(I’m guessing this is a field that is part of a testing suite, like Xray?)
It was fixed after I add "Requirement" to "Requirement Issue Types" in Xray settings.
Thank you for your help!
Excellent! 💪
