×Hi,
i use clones an issue and links post in some transitions. But post function transition is not executed because of null pointer exception.
The code that i'm using is:
issue.assigneeId = "testuser" def cf = customFieldManager.getCustomFieldObjectByName('Starting Date') val = issue.getCustomFieldValue(cf) - 1 issue.setDueDate(val)
The problem seems to start in line 3 of code because when i comment in the lines below line number 2 the code works but i cannot set the due date of the linked issue.
Any ideas?
Thanx in advance,
Kostas
I'm posting the logs i get when i'm trying to execute the post function
2012-07-19 13:02:33,317 http-8080-7 ERROR tsol 782x41004x1 1w9b7mx 10.0.8.115,10.0.8.55 /secure/CreateIssueDetails.jspa [onresolve.jira.groovy.GroovyFunctionPlugin] Error executing post-function javax.script.ScriptException: javax.script.ScriptException: java.lang.NullPointerException at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:117) at javax.script.AbstractScriptEngine.eval(Unknown Source) at javax.script.ScriptEngine$eval.call(Unknown Source) at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:120) at com.onresolve.jira.groovy.canned.utils.ConditionUtils.doAdditional(ConditionUtils.groovy:79) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:90) at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:233) at org.codehaus.groovy.runtime.callsite.StaticMetaMethodSite.invoke(StaticMetaMethodSite.java:43) at org.codehaus.groovy.runtime.callsite.StaticMetaMethodSite.call(StaticMetaMethodSite.java:88) at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:124) at com.onresolve.jira.groovy.canned.workflow.postfunctions.AbstractCloneIssue.doScript(AbstractCloneIssue.groovy:70) at com.onresolve.jira.groovy.canned.workflow.postfunctions.CopyIssueWithAttachments.super$2$doScript(CopyIssueWithAttachments.groovy) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:90) at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:233) at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1054) at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.invokeMethodOnSuperN(ScriptBytecodeAdapter.java:128) at com.onresolve.jira.groovy.canned.workflow.postfunctions.CopyIssueWithAttachments.doScript(CopyIssueWithAttachments.groovy:19) at com.onresolve.jira.groovy.canned.workflow.postfunctions.CloneIssue.super$3$doScript(CloneIssue.groovy) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:90) at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:233) at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1054) at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.invokeMethodOnSuperN(ScriptBytecodeAdapter.java:128) at com.onresolve.jira.groovy.canned.workflow.postfunctions.CloneIssue.doScript(CloneIssue.groovy:81) at com.onresolve.jira.groovy.canned.CannedScript$doScript.call(Unknown Source) at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116) at com.onresolve.jira.groovy.CannedScriptRunner.runCannedScript(CannedScriptRunner.groovy:57) at com.onresolve.jira.groovy.GroovyRunner.run(GroovyRunner.java:47) at com.onresolve.jira.groovy.GroovyFunctionPlugin.execute(GroovyFunctionPlugin.java:35) at com.opensymphony.workflow.AbstractWorkflow.executeFunction(AbstractWorkflow.java:869) at com.opensymphony.workflow.AbstractWorkflow.transitionWorkflow(AbstractWorkflow.java:1265) at com.opensymphony.workflow.AbstractWorkflow.initialize(AbstractWorkflow.java:618) at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:801) at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:461) at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:383) at com.atlassian.jira.bc.issue.DefaultIssueService.create(DefaultIssueService.java:193) at com.atlassian.jira.bc.issue.DefaultIssueService.create(DefaultIssueService.java:207) at com.atlassian.jira.web.action.issue.CreateIssueDetails.createIssue(CreateIssueDetails.java:96) at com.atlassian.jira.web.action.issue.CreateIssueDetails.doExecute(CreateIssueDetails.java:72) at webwork.action.ActionSupport.execute(ActionSupport.java:165) at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:76) at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:39) at webwork.interceptor.NestedInterceptorChain.proceed(NestedInterceptorChain.java:31) at webwork.interceptor.ChainedInterceptor.intercept(ChainedInterceptor.java:16) at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:35) at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:205) at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:143) at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:152) at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:74) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:103) at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:87) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:54) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:129) at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:77) at com.atlassian.jira.web.filters.PathExclusionFilter.doFilter(PathExclusionFilter.java:118) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:211) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:98) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:150) at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:71) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99) at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(JIRAProfilingFilter.java:19) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:350) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:81) at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:51) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.sysbliss.jira.plugins.workflow.servlet.JWDSendRedirectFilter.doFilter(JWDSendRedirectFilter.java:25) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:74) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:49) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.jira.web.monitor.ActiveRequestsFilter$PassToChainFilterFunc.doFilter(ActiveRequestsFilter.java:346) at com.atlassian.jira.web.monitor.ActiveRequestsFilter$DebugLogFilterFunc.doFilter(ActiveRequestsFilter.java:463) at com.atlassian.jira.web.monitor.ActiveRequestsFilter.doFilter(ActiveRequestsFilter.java:173) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:75) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.multitenant.servlet.MultiTenantServletFilter.doFilter(MultiTenantServletFilter.java:91) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:74) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:554) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859) at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588) at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489) at java.lang.Thread.run(Unknown Source) Caused by: javax.script.ScriptException: java.lang.NullPointerException at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:318) at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:111) ... 180 more Caused by: java.lang.NullPointerException at com.atlassian.jira.issue.customfields.impl.DateCFType.getDefaultValue(DateCFType.java:107) at com.atlassian.jira.issue.fields.CustomFieldImpl.getDefaultValue(CustomFieldImpl.java:1048) at com.atlassian.jira.issue.IssueImpl.getCustomFieldValue(IssueImpl.java:886) at com.atlassian.jira.issue.Issue$getCustomFieldValue.call(Unknown Source) at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116) at Script28.run(Script28.groovy:4) at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:315) ... 181 more
When we are using the "Clones an issue and links" post function and we are getting the value of a custom field that we will use it in the linked issue, in the custom field configuration the custom field should apply to issue type and project of the linked issue. Otherwise we will get errors.
I have added the logs in the body of my question.
Cheers
As others have said, post the full stacktrace.
I don't see why Date.minus() would throw an NPE, nor if .minus() was not available.
Perhaps cf is null.
I have added the logs the in body of my question.
Cheers
You need to think about what the customfield is returning in line 2 - whether it's nothing, null or an object that you can actually perform a "-1" operation with.
As Colin says, the logs should contain a stack trace which will tell you what is going wrong - have a look at that.
Is there more of a stacktrace? You could check to see if cf is null.
