OS: Ubuntu 17.04
Browser: Google Chrome Version 62.0.3202.75 (Official Build) (64-bit)
Issue: Every 3ish minutes, my Jira board will crash. Crashing meaning that I get Chrome's "Aww Snap, something went wrong". This issue is related to Chrome experiencing an issue loading the browser. I have not experienced this issue with other sites.
Edit: Here is the link to the Jira Bug per@Martin Varga: https://jira.atlassian.com/browse/JRACLOUD-67781
The vast majority of developers use Unix/Linux based systems. How can you not test Linux? At least 21% of devs use Linux. This is a paid product. And it's not exactly cheap.
"Right now, for Linux, the only supported browser is Firefox, so to avoid this bug, you will need to switch to a supported browser or platform, and in case this issue persists, we can raise a bug with our developer team."
Asking devs to switch platform is ludicrous. This is pretty unacceptable. According to this issue thread, this problem persists and also happens on FireFox:
I'm hopeful now that it has a high priority, but it has yet to have someone assigned to fix it (at the time of this post).
Here's a link to the Jira bug you are experiencing: https://jira.atlassian.com/browse/JRACLOUD-67781
Please watch the issue if you want to get updated on its progress.
Chrome: Version 63.0.3239.132 (Official Build) Built on Ubuntu , running on Ubuntu 16.04 (64-bit)
I wouldn't be exaggerating if I said every third or fourth page is crashing Chrome and giving me an "Aw, Snap!"
experiencing this as well, Vivaldi + Arch:
| Vivaldi | 1.13.1008.44 (Stable channel) (64-bit) |
| Revision | 0d3066937cd97722793fe96010ca2cf259bff114-refs/heads/master@{#527460} |
| OS | Linux |
| JavaScript | V8 6.2.414.43 |
| Flash | (Disabled) |
| User Agent | Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/62.0.3202.97 Safari/537.36 Vivaldi/1.94.1008.44 |
it's been happening for months now but happened to me twice in 15mins.
Experiencing this as well, chromium and debian.
This is fixed in JIRA Cloud. If you are using hosted version, you need to update it.
Brand new JIRA user, just experienced this today in JIRA Cloud (Approximately every 60-120 seconds), even after the upgrade to Chrome 64.0.3282.119.
I can't reproduce in Firefox - looks Chrome specific.
It does appear to especially happen while editing tasks....
And just this instant, I can't reproduce it, whereas it was happening all the time not 10 minutes ago. No wonder it's so hard to fix!
I'll keep my eye on it, see if it comes back.
Atlassian has an issue opened here: https://jira.atlassian.com/browse/JRACLOUD-67781
Also there is a Chromium issue here: https://bugs.chromium.org/p/chromium/issues/detail?id=782982
We should probably raise this as an Chrome issue... Atlassian doesn't care, but the chrome team will definitely care that a site can consistently crash their browser.
I think they care since they have the issue open.
But if they can't (or won't) solve the issue, I'll move my entire team to another solution. Nearly all of us run Linux and Chrome.
The issue is now in soaking phase. Changes have been made and are being tested now.
I have the same issue
Version 62.0.3202.75 (Official Build) Built on Ubuntu , running on Ubuntu 17.10 (64-bit)
Please make it fix.
I heard back from Atlassian support, here's what they wrote, sounds like they aren't going to fix this:
Hi Nick,
How are you today?
Unfortunetely, according to our Supported browsers page, Google Chrome is only supported for Mac and Windows, we cannot guarantee that it will work on Linux, it is not tested/developed to work for Google Chrome in Linux.
Could you please try to use JIRA for one day on Firefox and let us know if the issue persist?
Best regards,
Adalberto Schneider
Atlassian Cloud Support
Also happening for me on Ubuntu 16.04.
Crashes when navigating in the backlog or kanban board.
3GB out of 16GB in use so no memory issues at the system level.
Happening for me on Ubuntu 16.04.
This mostly happens when I'm in the agile board or in the backlog putting together a sprint.
I can reproduce it 100%. Easiest way is to go the backlog, and [ J ]/[ K ] through the list and it will definitely happen.
It will also do it as I do the same on issues in the agile board.
I've also had it happen pretty randomly while attempting to create new issues. I've submitted a few "feedback" messages. (Don't know if those just float off in the ether, or what.)
Pretty annoying, especially considering how much we're paying for JIRA and Confluence.
My rig is a i7-7700HQ, 16GB with less than half the memory in use. So I'm 99% sure I'm not running out of memory.
Same for Ubuntu 17.04 and chrome 62.0.3202.62.
Same here :
- Ubuntu 16.04 LTS
- Chrome 62.0.3202.75 (Official Build) (64-bit) (crashes occur with the ~2 previous versions)
My colleague also has the issue with Chromium + Debian
Happening to me as well.
$ cat /etc/redhat-release
CentOS Linux release 7.4.1708 (Core)
Does the problem only occur with Chrome or any other browser as well?
No I have not experience this problem with other browsers as of yet
Is the problem confined to just one user or does it happen with everyone?
As far as I know, I am the only that has experience the issue but I am also the only one on Ubuntu 17.04
What's the memory/RAM situation in the Task Manger when the crash occurs. Are the chrome tabs taking too many space?
Are any other pages being "Aww Snap-ed"?
The memory/RAM does not appear to be much different than normal. The issue has occured when my JIra task board was the only tab. The task board tab is the only that "Snaps out", even when I have other Jira related tabs open.
I will launch chrome from terminal with logging and see if any issues are logged to the terminal.
Browser seems updated to the latest version, so it's all covered from that angle.
Enable Logging in Chrome to see if there are any errors related to the crash.
See how to add command line flags for the enabling of logging.
I'm also getting this problem, looks like the same software versions:
Ubuntu 17.04
Log output from Chrome when it crashes is only:
# Fatal process OOM in heap setup
