Why doesn't Project Configurator create the project
Roy Chapman
Occaisionally, I get this error.  I can create the project and then run the importer, but why doesn't it create the project for me?  It usually does, why not this time?
An error occurred during the load:
Load failed for reason: Found reference to non existing project with key: JETBASE
INFO 10:28:54,177 Parsing XML file...
INFO 10:28:54,178 Starting to apply project configuration...
INFO 10:28:54,347 Creating project JETBASE Jetbase
WARN 10:28:54,398 Skipping users...
WARN 10:28:54,415 Skipping groups...
WARN 10:28:54,416 Skipping project roles...
INFO 10:28:54,460 Creating project category FICC IT
INFO 10:28:54,669 [Issue Type Issue] Modifying icon url to: /images/icons/issuetypes/genericissue.png
INFO 10:28:54,742 Creating issue type scheme Jetbase Issue Type Scheme
INFO 10:28:54,836 [Custom Field Ranking (Obsolete)] Creating configuration scheme [JETBASE]
WARN 10:28:54,842 Trying to rollback changes in database...
WARN 10:28:55,762 Rollback finished
com.awnaba.projectconfigurator.utils.errorhandling.XMLInputDataException: Found reference to non existing project with key: JETBASE
at com.awnaba.projectconfigurator.jiraobjectfacades.FieldToolsImpl.getJiraContexts(FieldToolsImpl.java:1544)
at com.awnaba.projectconfigurator.jiraobjectfacades.FieldToolsImpl.createFieldConfigScheme(FieldToolsImpl.java:1501)
at com.awnaba.projectconfigurator.loaders.handlers.CustomFieldConfigSchemeHandler.createNewTargetFrom(CustomFieldConfigSchemeHandler.java:450)
at com.awnaba.projectconfigurator.loaders.handlers.CustomFieldConfigSchemeHandler.createNewTargetFrom(CustomFieldConfigSchemeHandler.java:38)
at com.awnaba.projectconfigurator.loaders.core.AbstractIntegratedHandler$1.createNewFrom(AbstractIntegratedHandler.java:187)
at com.awnaba.projectconfigurator.loaders.core.AbstractSmartCreator.smartCreate(AbstractSmartCreator.java:13)
at com.awnaba.projectconfigurator.loaders.core.AbstractIntegratedHandler.shallowCreate(AbstractIntegratedHandler.java:202)
at com.awnaba.projectconfigurator.loaders.core.AbstractIntegratedHandler.createTarget(AbstractIntegratedHandler.java:160)
at com.awnaba.projectconfigurator.loaders.core.AbstractTargetHandler.handleTarget(AbstractTargetHandler.java:91)
at com.awnaba.projectconfigurator.loaders.core.CollectionMatcher.match(CollectionMatcher.java:27)
at com.awnaba.projectconfigurator.loaders.core.AbstractIntegratedHandler.handleOneTypeOfSubordinates(AbstractIntegratedHandler.java:301)
at com.awnaba.projectconfigurator.loaders.core.AbstractIntegratedHandler.handleSubordinateCollections(AbstractIntegratedHandler.java:286)
at com.awnaba.projectconfigurator.loaders.core.AbstractIntegratedHandler.handleSubordinatesAndProperties(AbstractIntegratedHandler.java:211)
at com.awnaba.projectconfigurator.loaders.core.AbstractIntegratedHandler.modifyTarget(AbstractIntegratedHandler.java:168)
at com.awnaba.projectconfigurator.loaders.core.AbstractTargetHandler.handleTarget(AbstractTargetHandler.java:93)
at com.awnaba.projectconfigurator.loaders.handlers.ProjectConfigLoader.loadGlobalCollection(ProjectConfigLoader.java:374)
at com.awnaba.projectconfigurator.loaders.handlers.ProjectConfigLoader.loadGlobalObjects(ProjectConfigLoader.java:187)
at com.awnaba.projectconfigurator.loaders.handlers.ProjectConfigLoader.loadOperations(ProjectConfigLoader.java:139)
at com.awnaba.projectconfigurator.loaders.handlers.ProjectConfigLoader.doLoad(ProjectConfigLoader.java:77)
at com.awnaba.projectconfigurator.ProjectConfigUploadPageAction.doLoad(ProjectConfigUploadPageAction.java:360)
at com.awnaba.projectconfigurator.ProjectConfigUploadPageAction.doExecute(ProjectConfigUploadPageAction.java:313)
at webwork.action.ActionSupport.execute(ActionSupport.java:165)
at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:88)
at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:39)
at webwork.interceptor.NestedInterceptorChain.proceed(NestedInterceptorChain.java:31)
at webwork.interceptor.ChainedInterceptor.intercept(ChainedInterceptor.java:16)
at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:35)
at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:225)
at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:154)
at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:152)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:87)
at com.atlassian.jira.web.filters.XContentTypeOptionsNoSniffFilter.doFilter(XContentTypeOptionsNoSniffFilter.java:22)
at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70)
at com.atlassian.jira.tzdetect.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:39)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
at com.atlassian.jira.baseurl.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:38)
at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25)
at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(ServingRequestsFilter.java:37)
at com.atlassian.greenhopper.jira.filters.ClassicBoardRouter.doFilter(ClassicBoardRouter.java:59)
at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFixupFilter.doFilter(PrettyUrlsSiteMeshFixupFilter.java:36)
at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:60)
at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:92)
at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:56)
at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:36)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:103)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:87)
at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:54)
at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:181)
at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:85)
at com.atlassian.jira.web.filters.SitemeshPageFilter.doFilter(SitemeshPageFilter.java:124)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61)
at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:239)
at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:100)
at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:172)
at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70)
at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:79)
at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99)
at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(JIRAProfilingFilter.java:19)
at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71)
at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:394)
at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:82)
at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:59)
at com.atlassian.jira.web.filters.gzip.JiraGzipFilter.doFilter(JiraGzipFilter.java:55)
at com.atlassian.analytics.client.filter.JiraAnalyticsFilter.doFilter(JiraAnalyticsFilter.java:40)
at com.atlassian.analytics.client.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:32)
at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:49)
at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:79)
at com.atlassian.jira.web.filters.MultipartBoundaryCheckFilter.doFilter(MultipartBoundaryCheckFilter.java:41)
at com.atlassian.jira.web.filters.JiraFirstFilter.doFilter(JiraFirstFilter.java:60)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1070)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:611)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:744)
José Marañón [Awnaba Software S.L.]
June 1, 2015
This is a known problem filed as PCP-270. Its difficulty lies in reproducing it. Typically, it happens in a test server, but not in a staging server with exactly the same data. Or, as in this case, sometimes it happens and sometimes it does not.
As you have already guessed, the workaround is quite simple: just create an empty version of the required project (a project with the same key will do).
In order to help us to reproduce and fix this bug, could you give us information (including versions) about:
  • The database JIRA is using
  • Its transaction isolation level
  • The application server
