I'm trying to get the Spartez SSH scanner working but getting the error below. I'm following the setup instructions here. Anyone know why this isn't working?
# python scanner.py --jira-url=https://jira.my.org/jira/ --jira-user=someuser --jira-password=somepass --self
Using default config file: default-config.xml
Scanning this computer...
------- Scanning host 127.0.0.1
Identifying OS...
Retrieving host MAC addresses for asset record matching...
Traceback (most recent call last):
File "scanner.py", line 49, in <module>
macs = scanner.scanMacAddresses(matcher)
File "/tmp/asset-tracker-scanner-1.0.1/scan/sshscanner.py", line 113, in scanMacAddresses
raise Exception('Unable to retrieve MAC addresses')
Exception: Unable to retrieve MAC addresses
Finished scanning
And another question: are you scanning a Mac or a Linux computer?
Hi Dave,
I am one of the developers at Spartez - the vendor behind Asset Tracker.
It seems that the scanner fails because it is unable to retrieve MAC addresses of your network adapters.
To diagnose this, can you check what is the output of the following command:
ifconfig | grep 'ether' | grep -v '00:00:00:00:00:00' | awk '{print $2}'
If this command returns empty string, it means that your ifconfig command returns something unexpected. In this case, can you invoke just
ifconfig
and let me know what the result is?
Best Regards
Janusz Gorycki, spartez.com
Ah, I see. There is no 'ether' on Linux for the MAC line in the ifconfig output. This works however:
# ifconfig | grep 'HWaddr' | awk '{print $5};'
ea:0f:a3:9e:df:18
Is there a switch to specify a Linux host?
Actually, OS should have been automatically detected. Somehow I assumed wrongly that you are on a Mac. For Linux, the command used by default for scanning is this one:
ip link list | grep 'link/' | grep -v '00:00:00:00:00:00' | awk '{print $2}'
What does it do in your case?
Also - you can try using the --verbose option to see what the scanner is trying to do.
Hrm..that works fine on the Linux host.
# ip link list | grep 'link/' | grep -v '00:00:00:00:00:00' | awk '{print $2}'
ea:0f:a3:9e:df:18
Ok, I know what is going on. Your only reported MAC address is ea:0f:a3:9e:df:18. This MAC is from the "private" address range (second byte is xA - ea:0f:a3:9e:df:18).
Such addresses are skipped, because they are not supposed to be used by "real" network adapters. So in effect the scanner is unable to detect that your computer has a network adapter, so it cannot uniquely identify it, so the scan is not performed.
Why do you have an adapter with "private" MAC address? Is this some specially configured machine? Perhaps it is some kind of virtual machine?
(sorry for the weird formatting. The input form went stupid on me)
Yes, this is a VM. The MAC is assigned from Proxmox. The IP address is on an internal LAN segment. I've changed the MAC to 00:15:17:c0:ff:ee and all is working now. I'd rather not change the MAC on every Proxmox (~60) host I have though. Could you add a switch to the command to ignore private MACs and report anyway?
# python scanner.py --jira-url=https://jira.my.org/jira/ --jira-user=someuser --jira-password=somepass --self --verbose
Identifying OS...
Command line: ['/bin/sh', '-c', 'uname ; hostname']
Detected OS: Linux
coston
Running command: ip link list | grep \'link/\' | grep -v \'00:00:00:00:00:00\' | awk \'{print $2}\'
Command line: ['/bin/sh', '-c', "ip link list | grep 'link/' | grep -v '00:00:00:00:00:00' | awk '{print $2}'"]
Received:
00:15:17:c0:ff:ee
Here is the --verbose output from earlier. It seems to find the MAC (just saw your request for this earlier). No prob on the formatting.
Identifying OS...
Detected OS: Linux
coston
Received:
ea:0f:a3:9e:df:18
File "scanner.py", line 46, in <module>
File "/tmp/asset-tracker-scanner-1.0.0/scan/sshscanner.py", line 113, in scanMacAddresses
Finished scanning
Ok, so we have a root cause then. If you insist on scanning the VM, you will have to modify the scanner source code, so that it allows private MAC addresses - at least ones with 'A' in the first byte. To do that, you will need to locate the file named
scan/sshscanner.py
in this file, go to line 109. Is thould look like this:
if len(mac) < 15 or mac[1].lower() == '2' or mac[1].lower() == '6' or mac[1].lower() == 'a' or mac[1].lower() == 'e':
make it look like this:
if len(mac) < 15 or mac[1].lower() == '2' or mac[1].lower() == '6' or mac[1].lower() == 'e':
Note however, that if you are going to scan multiple VMs, they may have their MACs duplicated - private MACs are not guaranteed to be unique and indeed sometimes they very much are NOT unique. So the scanner will end up overwriting records in Asset Tracker. To prevent that, you will need to configure your VMs so that they have unique MACs
Ah, I thought all the python scripts were compiled bytecode. I can certainly change this. I see the need to ignore private MACs if indexing is done from them. Thanks for the great response time one this! I will make sure all my VM MACS are unique before deploying this site-wide.
No problem, we are here to help.
By the way - you may find it more convenient to use our support Jira if you have any more questions - the address is https://jira.spartez.com/. Or, you can simply write an email to support@spartez.com - it will land in Jira also. This will give you the fastest of our support channels.
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
