In the JIRA field Fix Version, we have versions for multiple release types (Base, Custom, et al). I have added the release type in the Description fields for all Versions. I require the description to show in render dropdown on UI so people don't pick the wrong one for version overlaps (15.0 versus 15.0.0). Renderer only shows the number, not an associated description. Why does this not occur?
Running JIRA 5.04 (plans to upgrade to 5.1 within the next three months).
I've tested this through the terminal and worked. It needs to be placed somewhere in the view issue https://answers.atlassian.com/questions/131271
(function() { var versions = {}; if (AJS.Meta.get("issue-key")) { jQuery.get('/rest/api/2/project/' + AJS.Meta.get("issue-key").split("-")[0] + '/versions', function(json) { for (var i in json) { versions[json[i].id] = json[i].description; } }).then(function() { console.log("Versions", versions); console.log("Overwriting AJS.List.prototype._renders.suggestion"); AJS.List.prototype._renders.suggestion = function(descriptor, replacementText) { //adding the label as a class for testing. var idSuffix = descriptor.fieldText() || descriptor.label(); var itemId = AJS.escapeHTML(AJS.$.trim(idSuffix.toLowerCase()).replace(/[\s\.]+/g, "-")), listElem = AJS.$('<li class="aui-list-item aui-list-item-li-' + itemId + '"><a class="aui-list-item-link"/></li>'), linkElem = listElem.children(); if (descriptor.selected()) { listElem.addClass("aui-checked"); } if (this.options.hasLinks) { linkElem.attr("href", descriptor.href() || "#"); } if (descriptor.styleClass()) { linkElem.addClass(descriptor.styleClass()); } if (replacementText) { linkElem.html(replacementText); } else if (descriptor.html()) { linkElem.html(descriptor.html()); } else { linkElem.text(descriptor.label()); } if (descriptor.labelSuffix()) { var suffixSpan = AJS.$("<span class='aui-item-suffix' />").text(descriptor.labelSuffix()); linkElem.append(suffixSpan); } if (descriptor.icon() && descriptor.icon() !== "none") { var icon = AJS.$('<img class="icon" alt="" />'); icon.attr("src", descriptor.icon()); linkElem.addClass("aui-iconised-link").prepend(icon); } // Setting title with version description if (versions[descriptor.value()]) { descriptor.properties.title = versions[descriptor.value()]; } if (descriptor.title()) { linkElem.prop('title', descriptor.title()); } else { linkElem.prop('title', linkElem.text()); } listElem.data("descriptor", descriptor); return listElem; } }) } })();
Did you update the description in the correct field configuration?
@Jobin Kuruvilla [Go2Group] , yes - edited descriptions for the fix versions on Versions tab in applicable project for which I'm trying to get them to show.
(Just so we're clear - the description to be shown is not the FIELD "Fix Versions" but the descriptions for individual fix versions themselves)
Ah ok. There is no option to show the version description in the dropdown. It only shows the name. You can probably do it with the help of some javascript programming.
