Why is JIRA stuck on the Database Checklist Launcher?
Patrick Toma March 12, 2012
I have installed JIRA and pointed it to my Oracle 11G database, following all the steps as outlined in the documentation. It seems to be hanging on the Database Checklist Launcher but provides no further log info as to what might be happening. Did I miss something?
Thanks in advance,
Patrick
dbconfig.xml:
<?xml version="1.0" encoding="UTF-8"?>
<jira-database-config>
<name>defaultDS</name>
<delegator-name>default</delegator-name>
<database-type>oracle11g</database-type>
<schema-name></schema-name>
<jdbc-datasource>
<url>jdbc:oracle:thin:@orac6n1.pd.wdh.intuit.com:1521:JIRA01</url>
<driver-class>oracle.jdbc.OracleDriver</driver-class>
<username>********</username>
<password>*********</password>
<pool-size>15</pool-size>
</jdbc-datasource>
</jira-database-config>
catalina.out:
Using CATALINA_BASE: /apps/tomcat
Using CATALINA_HOME: /apps/tomcat
Using CATALINA_TMPDIR: /apps/tomcat/temp
Using JRE_HOME: /usr
Using CLASSPATH: /apps/tomcat/bin/bootstrap.jar
[root@scm03 logs]# ls
catalina.2012-03-13.log catalina.out host-manager.2012-03-13.log localhost.2012-03-13.log manager.2012-03-13.log
[root@scm03 logs]# cat catalina.out
Mar 13, 2012 9:26:26 AM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/java/jdk1.6.0_18/jre/lib/amd64/server:/usr/java/jdk1.6.0_18/jre/lib/amd64:/usr/java/jdk1.6.0_18/jre/../lib/amd64:/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
Mar 13, 2012 9:26:26 AM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
Mar 13, 2012 9:26:26 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 505 ms
Mar 13, 2012 9:26:26 AM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Mar 13, 2012 9:26:26 AM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.35
Mar 13, 2012 9:26:26 AM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor jira.xml
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/apps/apache-tomcat-6.0.35/lib/slf4j-log4j12-1.5.8.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/apps/apache-tomcat-6.0.35/webapps/jira/WEB-INF/lib/slf4j-log4j12-1.5.8.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
2012-03-13 09:26:27,941 main INFO [jira.config.database.SystemTenantDatabaseConfigurationLoader] Reading database configuration from /apps/jira-home/dbconfig.xml
2012-03-13 09:26:28,176 main INFO [atlassian.jira.startup.JiraStartupLogger]
JIRA starting...
2012-03-13 09:26:28,194 main INFO [atlassian.jira.startup.JiraStartupLogger]
___ Environment _____________________________
JIRA Build : 5.0#713-sha1:aec58e27a0d402341b1f1be2fc8c0204a0b070f6
Build Date : Wed Feb 15 00:00:00 PST 2012
JIRA Installation Type : EAR/WAR
Application Server : Apache Tomcat/6.0.35 - Servlet API 2.5
Java Version : 1.6.0_18 - Sun Microsystems Inc.
Current Working Directory : /apps/apache-tomcat-6.0.35/logs
Maximum Allowable Memory : 455MB
Total Memory : 122MB
Free Memory : 87MB
Used Memory : 35MB
Memory Pool: Code Cache : Code Cache: init = 2555904(2496K) used = 1211776(1183K) committed = 2555904(2496K) max = 50331648(49152K)
Memory Pool: PS Eden Space : PS Eden Space: init = 33554432(32768K) used = 32788048(32019K) committed = 33554432(32768K) max = 167772160(163840K)
Memory Pool: PS Survivor Space : PS Survivor Space: init = 5570560(5440K) used = 2410056(2353K) committed = 5570560(5440K) max = 5570560(5440K)
Memory Pool: PS Old Gen : PS Old Gen: init = 89522176(87424K) used = 2145104(2094K) committed = 89522176(87424K) max = 357957632(349568K)
Memory Pool: PS Perm Gen : PS Perm Gen: init = 21757952(21248K) used = 18665640(18228K) committed = 21757952(21248K) max = 268435456(262144K)
JVM Input Arguments : -Djava.util.logging.config.file=/apps/tomcat/conf/logging.properties -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Dmail.mime.decodeparameters=true -Xms128m -Xmx512m -XX:MaxPermSize=256m -Djava.endorsed.dirs=/apps/tomcat/endorsed -Dcatalina.base=/apps/tomcat -Dcatalina.home=/apps/tomcat -Djava.io.tmpdir=/apps/tomcat/temp
___ Java System Properties _________________
catalina.base : /apps/tomcat
catalina.home : /apps/tomcat
catalina.useNaming : true
common.loader : ${catalina.base}/lib,
${catalina.base}/lib/*.jar,
${catalina.home}/lib,
${catalina.home}/lib/*.jar
file.encoding : UTF-8
file.encoding.pkg : sun.io
java.awt.graphicsenv : sun.awt.X11GraphicsEnvironment
java.awt.printerjob : sun.print.PSPrinterJob
java.class.version : 50.0
java.home : /usr/java/jdk1.6.0_18/jre
java.io.tmpdir : /apps/tomcat/temp
java.naming.factory.initial : org.apache.naming.java.javaURLContextFactory
java.naming.factory.url.pkgs : org.apache.naming
java.runtime.name : Java(TM) SE Runtime Environment
java.runtime.version : 1.6.0_18-b07
java.specification.name : Java Platform API Specification
java.specification.vendor : Sun Microsystems Inc.
java.specification.version : 1.6
java.util.logging.config.file : /apps/tomcat/conf/logging.properties
java.util.logging.manager : org.apache.juli.ClassLoaderLogManager
java.vendor : Sun Microsystems Inc.
java.vendor.url : http://java.sun.com/
java.vendor.url.bug : http://java.sun.com/cgi-bin/bugreport.cgi
java.version : 1.6.0_18
java.vm.info : mixed mode
java.vm.name : Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name : Java Virtual Machine Specification
java.vm.specification.vendor : Sun Microsystems Inc.
java.vm.specification.version : 1.0
java.vm.vendor : Sun Microsystems Inc.
java.vm.version : 16.0-b13
mail.mime.decodeparameters : true
org.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER : true
os.arch : amd64
os.name : Linux
os.version : 2.6.18-274.18.1.0.1.el5
package.access : sun.,
org.apache.catalina.,
org.apache.coyote.,
org.apache.tomcat.,
org.apache.jasper.,
sun.beans.
package.definition : sun.,
java.,
org.apache.coyote.,
org.apache.tomcat.,
org.apache.jasper.
server.loader :
shared.loader :
sun.arch.data.model : 64
sun.boot.library.path : /usr/java/jdk1.6.0_18/jre/lib/amd64
sun.cpu.endian : little
sun.cpu.isalist :
sun.io.unicode.encoding : UnicodeLittle
sun.java.launcher : SUN_STANDARD
sun.jnu.encoding : UTF-8
sun.management.compiler : HotSpot 64-Bit Server Compiler
sun.os.patch.level : unknown
tomcat.util.buf.StringCache.byte.enabled : true
user.country : US
user.dir : /apps/apache-tomcat-6.0.35/logs
user.home : /root
user.language : en
user.name : root
user.timezone : US/Pacific
2012-03-13 09:26:28,194 main INFO [atlassian.jira.startup.JiraStartupLogger] Running JIRA startup checks.
2012-03-13 09:26:28,242 main INFO [atlassian.jira.startup.JiraHomeStartupCheck] The jira.home directory '/apps/jira-home' is validated and locked for exclusive use by this instance.
2012-03-13 09:26:28,243 main INFO [atlassian.jira.startup.JiraStartupLogger] JIRA pre-database startup checks completed successfully.
2012-03-13 09:26:28,465 main INFO [jira.config.database.SystemTenantDatabaseConfigurationLoader] Reading database configuration from /apps/jira-home/dbconfig.xml
2012-03-13 09:26:28,552 main INFO [jira.config.database.DatabaseConfigurationManagerImpl] Now running Database Checklist Launcher
Deleted user March 13, 2012
We got the exactly same problem.
The cause was SQL Server not running properly: JIRA could not access/write into its database...
Anandhi A January 31, 2013
I also have the same problem....How do i solve it...Memory space is available..no problem with it...There is nothing in logs also..
Thanks in advance.
Nic Brough -Adaptavist-
January 31, 2013
The original poster says there was a database issue - can you test the database settings from the Jira server?
I am connecting to a remote database using IP address and SID. When i tested the connection after providing the database details in the Configuration Tool, it was successful.
January 31, 2013
Ok, good. Could you test it outside Jira - make sure the user that Jira is using to connect with has full read/create/delete/index rights?
Anandhi A February 3, 2013
The user has full rights...but JIRA is stuck up during startup. There is nothing else in the logs except the same message "Now Running Database Checklist Launcher"...:(
RomanLutsiv
March 3, 2016
Jobin Kuruvilla [Adaptavist]
March 12, 2012
Any error in the tomcat catalina logs? Like out of memory? How long is it hanging for?
Jo-Anne MacLeod
March 12, 2012
I'm with Jobin here, how is the memory? disk space?
There are no other errors.. its been hanging for over 3 hours.
