When I navigate to an Issue from the Gadget "Filter Results" in my Dashboard and then come back to the Dashboard, the Gadget "Filter Results" is not dispalyed anymore. I need to re-load the page (mostly several times) to get the Gadget displayed again.
Is there anything I can do to solve this problem? Has anybody had this problem too
Welcome to community!
Do you know which version of Jira you are on? And if so are you using Chrome? There was a chrome bug fixed in 8.20.6 I believe (may have been 8.20.7) or 8.22.1 so you're Jira instance may need an upgrade.
Best,
Clark
I am on Jira Version 8.20.1 and using MS Edge.
Is this a known bug for MS Edge? Will an update help?
