I have Project X with two boards: Board A and Board B
In the backlog section of Board A sprint Z contains issues: issue1, issue2, issue3, issue4, issue5
In the backlog section of Board B sprint Z (same sprint name) only shows issues: issue1, and issue2
Why are issues 3/4/5 not showing on Board B even though they have been assigned to the same sprint?
Hi @Tom Garland Please check the board filter and sub-filter. Try to put both these Board filter queries in the Issue advanced search and see if they return same results. Even if issue 3 is part of Sprint Z on both Board A and Board B, it will be shown only when the Board filter allows it. Hope this helps!
Many thanks @Anandhi Arumugam _Cprime_
So would I be right in thinking the following:
Hi @Tom Garland
To answer your questions,
1. A project (eg: My Scrum Project 1) can have one or more Sprints named Sprint Z
2. Projects My Scrum Project 1 and My Scrum Project 2 can have one or more Sprints named Sprint Z
3. More than the name, each sprint have an ID that matters. The ID will be unique for each sprint across Jira system.
4. When you create a board filter, you need to make sure you pick the right Sprint ID to show the issues. If you want issues to show from My Scrum Project 1 - Sprint Z (id 40) and My Scrum Project 2 Sprint Z (id 5), then your filter should look like
project IN ("My Scrum Project 1", "My Scrum Project 2") AND Sprint IN (40, 5) ORDER BY created DESC
Hope this helps!
Glad to help! If that worked for you please accept the answer :)
