Why jira is using multiple java processes?
Tejas Naik June 15, 2023
Hi Team,
We seem to like running out of ram (16gigs) memory for the 350K issues, 700 custom fields
, 40+ workflows, 2K users Jira server. Is this 16gigs of RAM enough or should we increase the RAM size?
And I have observed Jira user is using multiple Java processes
Server details
# free -m
           total    used    free   shared   buffers cached
Mem: 15935  15770   165      0           8          334
-/+ buffers/cache: 15427 508
Swap: 5118     2904  2214
# top | grep java
106321 jira 20 0 19.7g 9.3g 87m S 3.9 59.6 469:04.11 java
101190 jira 20 0 17.7g 5.2g 7424 S 2.0 33.7 44:33.64 java
Thanks and Regards
Tejas
2 accepted
Mohamed Benziane
Tejas Naik June 16, 2023
@Mohamed Benziane Thanks
Do you know, why Jira user is using multiple Java processes?
# top | grep java
Regards
Tejas
Nic Brough -Adaptavist-
June 17, 2023
Java can handle multiple threads running the same thing, and "top" might not be reporting as you guess it would.  Depending on your distribution, try "htop" and "systemctl status", they may give you more detail on what is happening.
Your "top" just tells us that there are two Java (not necessarily Jira) processes are running, so you need to look at more detail on both of them to find out what it is doing.
If it's not a systemd install and you don't have htop, try "ps -ef | grep -i java" - that should tell you what the two java processes are (only one of them will be Jira-on-tomcat unless you've managed to configure two)
Tejas Naik June 26, 2023
Hi @Nic Brough -Adaptavist-
Thanks for the reply, so sorry for my delayed response, I was fallen sick.
I tried running the command "ps -ef | grep -i java" and I do see two Java processes running the same Jira process, not sure if this is expected or if I have done any configuration issues during the last upgrade.
Result:
root      72008  71977  0 06:45 pts/0    00:00:00 grep -i java
jira     101190      1  0 Jun26 ?        00:53:19 /opt/gtnexus/jdk-11.0.4+11/bin/java
-Djava.util.logging.config.file=/opt/gtnexus/atlassian-jira/conf/logging.properties
-Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Xms6144m -Xmx7168m -XX:InitialCodeCacheSize=32m -XX:ReservedCodeCacheSize=512m
-Djava.awt.headless=true -Datlassian.standalone=JIRA -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Dmail.mime.decodeparameters=true
-Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory -Dcom.arsenalesystems.dataplane.db.maxConnections=40 -Dmail.debug=true
-Djava.net.preferIPv4Stack=true -XX:-OmitStackTraceInFastThrow -Djava.locale.providers=COMPAT -Djdk.tls.ephemeralDHKeySize=2048
-Djava.protocol.handler.pkgs=org.apache.catalina.webresources
-Dorg.apache.catalina.security.SecurityListener.UMASK=0027 -Xlog:gc*:file=/opt/gtnexus/atlassian-jira/logs/atlassian-jira-gc-%t.log:tags,time,uptime,level:
filecount=5,filesize=20M -XX:+ExplicitGCInvokesConcurrent
-Dignore.endorsed.dirs= -classpath /opt/gtnexus/atlassian-jira/bin/bootstrap.jar:/opt/gtnexus/atlassian-jira/bin/tomcat-juli.jar
-Dcatalina.base=/opt/gtnexus/atlassian-jira -Dcatalina.home=/opt/gtnexus/atlassian-jira
-Djava.io.tmpdir=/opt/gtnexus/atlassian-jira/temp org.apache.catalina.startup.Bootstrap start
jira     106321      1 14 Jun26 ?        13:24:15 /opt/gtnexus/jdk-11.0.4+11/bin/java
Regards
Tejas
June 26, 2023
That looks like you are running Jira twice, which should not be possible for more than a few seconds (the first one running should have created lock data that would prevent the second starting up).
I strongly recommend shutting them all down completely, and starting it again.  I'd also want to investigate why the duplicate-detection didn't work.
Like • Tejas Naik likes this
Teja
June 27, 2023
Hi Nic,
Sure, let me stop and start.
Regards
Tejas
