Hi!
I just want to ask for some help. I made a web item in my atlassian-plugin.xml:
<web-item key="web-item-example" name="My Web Item" section="operations-delete" weight="200">
<description key="my-web-item-desc">General description</description>
<label>Push me</label>
<link linkId="my_web_item_link"/>
</web-item>
And i wrote my js like this:
AJS.toInit(function(){
AJS.$('#my_web_item_link').click(function(e){
alert("Documentation");
When i press the web item happening nothing. Can you help me?
I dont know why my code is not working.
I could not solve this problem with web-item, but if somebody needs help then use javascript and put a label into the more operationbar. My soultion is the next:
$('#opsbar-operations_more_drop').append('<div class="aui-dropdown2-section"><ul><li class="aui-list-item"><a href="#" id="listDialog"><span class="trigger-label">PD rendering</span></a></li></ul></div>');
* Open your Web Developer tools in Chrome / Firefox. Do you see any errors / warnings?
* Maybe AJS.toInit() is not executing your code at the right time. You could try it with
$(document).ready()
Or with
$(window).on('load', function() { //do something})
It is already solved. If i push the button, then the link automaticly load the main page, so it can not call the functions before it. To solve this problem you should put in the link "#". In this case the fucntions will be called (i tried it with only button, not web item).
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
