  • Community
  • Q&A
  • Jira
  • Questions
  • Why would Code Committed Condition not allow me to transition when code has been commited against this issue?
Karl Shlayfman
Why would Code Committed Condition not allow me to transition when code has been commited against this issue? I do see under Subversion commit tab in JIRA that code has been commited. Any suggestions?
pkirkeby
January 26, 2016
The 'Code Commited Condition' is only for FishEye commits: https://jira.atlassian.com/browse/FE-5726
Jobin Kuruvilla [Adaptavist]
August 13, 2012
Are you sure the committed message has the issue key in it? The code will appear in source tab even if it is not there depending on how you configured it - sometimes it shows all code in the project under source tab.
Karl Shlayfman
Yes it does have a issue number in the commit message. I see the file I commited through JIRA under Subversion Commit tab. What strange is that even when i change my condition to allow transition even if code has not been commited it is still not showing my transition.
August 13, 2012
There must be something else going on then. Are there any other conditions in the workflow transition? If not, check the logs.
Karl Shlayfman
No other conditions.
Upcoming Jira Events
