I would like to default the style of custom field (text type). Make it red and bold.
How can I do it ?
look like this in the field configuration:
look like this in the issue screen (when Im choosing the red color):
Hello Daniel,
To set a custom field with a formatted default value as you need (Red and Bold), you must perform the following steps:
- Navigate to the Field Configuration of your project > Find the custom field > Click on Renderers and enable the Wiki Style Renderer
- Navigate to the custom field page > Find the custom field > Click on Configure
- Click Set Default Value and then add it in the following format:
{color:red}*the text you want*{color}
Please, let me know if it works for you.
Hi @Petter Gonçalves ,
unfortunately , it didn't work...
I need to set only the properties (red and bold) and not the value.. the value will fill with workflow post function that already worked.
