×Hey there,
We're using Jira Core 7.7.1 and have trouble with the wiki style renderer for the description field. This renderer has many features and all of them are working except the image display. We used this syntax: !imageName.jpg! or !imageName.jpg|thumbnail! but instead of the image the text is displayed. It doesn't matter which browser we use. Does anybody have an idea what's going wrong?
Thanks a lot!
You could be running into this problem: https://confluence.atlassian.com/jirakb/image-attachments-are-not-displayed-inline-in-wiki-renderer-fields-723518199.html
Can you please try the suggested workaround which is:
To display inline images in JIRA fields try set the "Internet Explorer MIME Sniffing Security Hole Workaround Policy" option to either "Insecure: inline display of attachments" or "Work around Internet Explorer security hole".
Worked perfectly
Thank you very much
