Wiki style renderer for custom field not applying in Create Issue Screen
Jofffinn
October 23, 2017
I created new screens and screens schemes so that a specific Custom field (text multi line, Wiki Style Renderer) is displayed on Create Issue Screen
The custom field appears but NOT as a Wiki Style rendered box
The pre-defined text (set as default in custom field configuration) I entered there show *this is a test* instead of this is a test in the Create Issue Screen
The custom field is set to only be shown with 1 specific issue type for 1 specific project.
Now curious thing is that when I select this special screen scheme a s default and applied to all issue types, it does shows as wiki style rendered randomly for some other issue type that the one I want.
Any idea?
Tayyab Bashir
October 23, 2017
You need to change the render of your custom field.
Go to the field configuration scheme which is custom field is using for that specific project.
Then in field configuration find your custom field and set its renderer to [Wiki Style Renderer] instead of Default Text renderer.
Your custom field would then start to pick up Wiki Style rendering.
Jofffinn
October 23, 2017 edited
Thx @Tayyab Bashir Actually problem was that I somehow updated the wiki style rendering of my custom field not for this specific screen scheme...
thx a lot works perfectly now
Register here ⬇️
