Will JIRA upgrade would have an impact on existing columns?
Pooja
Hi All,
we would like to access the JIRA database to be able to build the MIS reports for our Daily/Weekly/Monthly status reporting to Management.
If any JIRA upgrade would have an impact on existing columns?
Pooja
DPKJ
@PoojaJira doesn't upgrade database schema that often (last update was in 7.9.2), but this is still not a recommended way to generate reports etc.
I suggest you use REST API's for this.
Pooja
Hi @DPKJ
May I know some of the API lists which can cater to my requirements?
DPKJ
Have a look this API - https://docs.atlassian.com/software/jira/docs/api/REST/8.4.1/#api/2/search
Also this page contains all the public REST api provided by Jira.
Register now
