Without Automation, how to get an email notification when a Blocker issue is created?
leodavesne May 11, 2023
Hi, I'm searching for a way to get notified by email when a new Blocker issue is created.
Even better if I could set up some other users to get notified.
Additional note: unfortunately I cannot use the Automation plugin for that.
Michael Wohlgemuth
May 11, 2023
Yo @leodavesne
you could create a JQL like
project = XXX and priority = Blocker
then save it as filter, and then set up a subscription to this filter for you or the users you wish to get notified. You can configure how often it will run, too.
Might fit you needs.
Have a great day!
Upcoming Jira Events
