Work Description Field
Madeleine Carswell
September 15, 2016
Hello all,
When we create an issue of type User Story the field Work Description is available, but once the story is created we can no longer view this field anywhere, including if we then go back in and edit the story. Is there something we need to have changed by an admin to be able to view this field?
Many thanks,
3 votes
Phil Barton
October 10, 2017
Just ran into this today, had a user report exactly the same thing.
The Work Description field is part of the Log Work fields.  Those fields are not clearly marked as Log Work fields on the create screen, but it appears that if you don't enter the time spent a few entries above Work Description it doesn't save it.
So, in summary, Time Spent, Date Started, Remaining Estimate and Work Description all go together as part of the Log Work stuff.  Very unclear when looking at the entire create issue screen as a whole.
Jennifer
I'm only able to select the Log Work tab and select Edit to input a work description
The field is not displaying on my Edit/View screen but it does display on my Create screen
Michael Hönes June 16, 2020
I'm facing the same issue. Work Description is available on the create screen but not on the edit screen although the Log Work field is added to the edit screen
Like staceyking likes this
noamdah
September 15, 2016
Yes, there is a different screen for each state (Create, View, Edit)
Go to the relevant project => Project Admin => Screens
And add the Work Description field to all screens.
Check out this link and this link.
Nic Brough -Adaptavist-
September 15, 2016
It sounds like the field is on the "create issue" screen, but not the "edit issue" screen.
Get the admin to check the project's "Issue type screen scheme" to check that.
