Work Log
Bryan Nielsen February 25, 2019
Is there a way to show a work log for every time I log work for an item
2 accepted
Sebastian BrudziƄski
Hello @Bryan Nielsen
Jira allows you to view the total time logged into a particular ticket, but it doesn't offer a way to display a total time logged by a particular user. There are several apps available on the Atlassian Marketplace, but they are usually quite robust (more than simple time tracking) and therefore expensive. One of the cheap, light-weight solutions for time tracking has been developed by us and is available for Jira Cloud and Jira server - Worklogs - Time Reports for Jira
It allows you to view the total time you logged to particular projects, and additionaly group the time by issue type, priority or other fields of your choice.
Best,
Sebastian.
Bryan Nielsen February 26, 2019
Ok thank you so much for the help
Jack Hunter [HeroCoders]
February 25, 2019 edited
There is a Worklog tab available on every issue page (next to Comments) that shows all the logged entries.
Is this what you need?
If you want more, then please take a look at Clockwork Automated Timesheets. It gives more insight into tracked time.
Jack
I'm hoping for something that would list all the work logged for all my issues. Anything like that?
Tanya Gordon
February 25, 2019
You can try the tempo timesheet app, very recommended :-)
Not a bad idea. Anything already built in anyone?
Deniz Oğuz - The Starware
February 25, 2019
It may be an overkill but you may also try WorklogPRO. Timesheet view, calendar view does exactly what you are looking for.
Thank you
Take a look at Clockwork Automated Timesheets in that case.
Bryan Nielsen February 27, 2019
Thank you!
